Allows you to change the MEP ID for a previously configured MEP. Each MEP within a single MA must have a unique MEP ID.
domain_name |
Enter the domain associated with the MA you are configuring. |
association_name |
IEEE 802.1ag or ITU-T Y.1731 association name. |
port_list |
Enter the port number you want to change the MEP ID. |
up |
Enter this variable if you are changing the MEP ID on an UP MEP. |
down |
Enter this variable if you are changing the MEP ID on a DOWN MEP. |
mepid |
Enter the new value for this MEP. The range is 1 to 8191. NOTE: On each MA, each MEPID must be unique. |
N/A.
Use this command to change the MEPID on a previously configured UP or DOWN MEP. If you attempt to change the MEPID on a port that is either not an MEP or having wrong MEP type, the system returns an error message.
Use the show cfm command to verify your configuration.
The following command changes the MEP ID to 75 on the previously configured port 2:4 UP MEP on the 350 association in the finance domain:
configure cfm domain finance association 350 ports 2:4 end-point up mepid 75
This command was first available in ExtremeXOS 11.4.
